ONTAP EMS reference
sfu.fcdownloadfailed events
sfu.fcdownloadfailed EMS events occur when a disk shelf firmware update fails to download shelf firmware to an FC or an ATA shelf successfully.
sfu.FCDownloadFailed
Severity
ERROR
This message occurs when a disk shelf firmware update fails to download shelf firmware to an FC or an ATA shelf successfully.
Corrective Action
Redownload the latest disk shelf firmware from the NetApp Support Site at https://mysupport.netapp.com/site/downloads/firmware/disk-shelf-firmware and attempt to download disk shelf firmware again by using the (advanced privilege) "storage shelf firmware update" command.
Syslog Message
%s: Download failed on %s on ES controller module %s via SES device %s.%d on %s.shelf%d.
cmdName (STRING): Name of the command issued, such as "storage shelf firmware update".
fileName (STRING): Name of file in /etc/shelf_fw that was being downloaded.
module (STRING): Module A is the upper module in the enclosure on the back side. Module B is the lower module in the enclosure on the back side.
channelNameSES (STRING): Name of the adapter port or switch port on the SES services device on which the disk shelf firmware download failed.
scsiId (INT): SCSI ID of the SES services device used to download disk shelf firmware.
channelNameShelf (STRING): Name of the adapter port or switch port on which the disk shelf firmware download failed.
shelfId (INT): ID of the disk shelf on which the disk shelf firmware download failed.
