sfu.fcdownloadfailed events
sfu.fcdownloadfailed EMS events occur when a disk shelf firmware update fails to download shelf firmware to an FC or an ATA shelf successfully.
sfu.FCDownloadFailed
- Severity
ERROR
- Description
This message occurs when a disk shelf firmware update fails to download shelf firmware to an FC or an ATA shelf successfully.
- Corrective Action
Redownload the latest disk shelf firmware from the NetApp Support Site at https://mysupport.netapp.com/site/downloads/firmware/disk-shelf-firmware and attempt to download disk shelf firmware again by using the (advanced privilege) "storage shelf firmware update" command.
- Syslog Message
%s: Download failed on %s on ES controller module %s via SES device %s.%d on %s.shelf%d.
- Parameters
cmdName (STRING): Name of the command issued, such as "storage shelf firmware update".
fileName (STRING): Name of file in /etc/shelf_fw that was being downloaded.
module (STRING): Module A is the upper module in the enclosure on the back side. Module B is the lower module in the enclosure on the back side.
channelNameSES (STRING): Name of the adapter port or switch port on the SES services device on which the disk shelf firmware download failed.
scsiId (INT): SCSI ID of the SES services device used to download disk shelf firmware.
channelNameShelf (STRING): Name of the adapter port or switch port on which the disk shelf firmware download failed.
shelfId (INT): ID of the disk shelf on which the disk shelf firmware download failed.
