ONTAP EMS reference
scsiblade.san events
scsiblade.san EMS events occur when ONTAP encounters issues associated with SAN active-active state and SnapMirror® Active Synchronous operations.
scsiblade.san.config.active
Severity
NOTICE
This message occurs when the SAN active-active state has changed.
Corrective Action
(None).
Syslog Message
The symmetric active-active state is %s on %lld LUNs.
state (STRING): Active-active state.
num_luns (INT): Number of LUNs.
scsiblade.san.rtpgid.err
Severity
ERROR
This message occurs when a report target port group ID space inconsistency between cluster peers is detected. This can result in no I/O progress or I/O disruption or both on the host.
Corrective Action
Recovery from inconsistency is required. Please contact Contact NetApp technical support. for assistance.
Syslog Message
Consistency group that has LUN %s is in an inconsistent state.
LUNSerialNumber (STRING): Serial number of the LUN.
scsiblade.san.ssm.lu.degraded
Severity
ALERT
This message occurs when a LUN is marked as degraded due to a SnapMirror® Active Synchronous relationship going out of sync. The LUN is no longer accessible from the host.
Corrective Action
Restore LUN access to the host by using the "snapmirror resync" command to bring the out-of-sync relationship back in sync. For assistance, contact technical support.
Syslog Message
LUN %s was marked as degraded due to a SnapMirror Active Synchronous relationship going out of sync.
scsiblade.san.ssm.lu.online
Severity
NOTICE
This message occurs when a LUN is back online and might be accessible again from the host.
Corrective Action
If the host still can't access the LUN even though the LUN is back online, perform a host-side rescan operation or a reboot to enable the host to access the LUN.
Syslog Message
LUN %s is back online.
