scsiblade.san events
scsiblade.san EMS events occur when ONTAP encounters issues associated with SAN active-active state and SnapMirror® Active Synchronous operations.
scsiblade.san.config.active
- Severity
NOTICE
- Description
This message occurs when the SAN active-active state has changed.
- Corrective Action
(None).
- Syslog Message
The symmetric active-active state is %s on %lld LUNs.
- Parameters
state (STRING): Active-active state.
num_luns (INT): Number of LUNs.
scsiblade.san.rtpgid.err
- Severity
ERROR
- Description
This message occurs when a report target port group ID space inconsistency between cluster peers is detected. This can result in no I/O progress or I/O disruption or both on the host.
- Corrective Action
Recovery from inconsistency is required. Please contact Contact NetApp technical support. for assistance.
- Syslog Message
Consistency group that has LUN %s is in an inconsistent state.
- Parameters
LUNSerialNumber (STRING): Serial number of the LUN.
scsiblade.san.ssm.lu.degraded
- Severity
ALERT
- Description
This message occurs when a LUN is marked as degraded due to a SnapMirror® Automated Failover relationship going out of sync. The LUN is no longer accessible from the host.
- Corrective Action
Restore LUN access to the host by using the "snapmirror resync" command to bring the out-of-sync relationship back in sync. For assistance, contact NetApp Support.
- Syslog Message
LUN %s was marked as degraded due to a SnapMirror Automated Failover relationship going out of sync.
- Parameters
scsiblade.san.ssm.lu.online
- Severity
NOTICE
- Description
This message occurs when a LUN is back online and might be accessible again from the host.
- Corrective Action
If the host still can't access the LUN even though the LUN is back online, perform a host-side rescan operation or a reboot to enable the host to access the LUN.
- Syslog Message
LUN %s is back online.
- Parameters
