ONTAP EMS reference
nblade.flexcachevolumeaccess events
nblade.flexcachevolumeaccess EMS events occur when a client tries to access a FlexCache volume through an unsupported protocol.
Nblade.flexCacheVolumeAccess
Severity
ERROR
This message occurs when a client tries to access a FlexCache volume through an unsupported protocol. Currently only NFSv3,NFSv4,NFSv4.1 and SMB clients are supported by FlexCache.
Corrective Action
Make sure a FlexCache-supported protocol is specified for all client mount operations through which a FlexCache volume can be accessed. If using FlexCache, specify 'nfsvers=3' or 'nfsvers=4' or 'nfsvers=4.1' as an option for the 'mount' command on all clients accessing a FlexCache volume.
Syslog Message
Attempt to access FlexCache volume with Master Data Set ID %u in SVM %s via %s denied for client %s.
volMsid (INT): Master Data Set ID of the FlexCache volume being accessed.
vserverName (STRING): Name of the vserver associated with this operation.
protocol (STRING): Client protocol.
clientIpAddress (STRING): IP address of the client machine.
