nblade.flexcachevolumeaccess events
Nblade.flexCacheVolumeAccess
Severity
ERROR
This message occurs when a client tries to access a FlexCache volume through an unsupported protocol. Currently only NFSv3 clients are supported by FlexCache.
Corrective Action
Make sure a FlexCache-supported protocol is specified for all client mount operations through which a FlexCache volume can be accessed. If using FlexCache, specify 'nfsvers=3' as an option for the 'mount' command on all clients accessing a FlexCache volume
Syslog Message
Attempt to access FlexCache volume with MSID %u via %s denied.
msid (INT): MSID of the FlexCache volume being accessed.
protocol (STRING): Client protocol.
