ONTAP EMS reference
acp.sock events
acp.sock EMS events occur when the system encounters a socket error while setting up the Alternate Control Path (ACP) Management Ethernet port.
acp.sock.error
Severity
ERROR
This message occurs when the system encounters a socket error while setting up the Alternate Control Path (ACP) Management Ethernet port. ACP functionality is subsequently inactive.
Corrective Action
Verify that the Ethernet cable is properly attached to the ACP port and that the green LED is on. Reenable the ACP using the "options acp.enabled on" command.
Syslog Message
An error was encountered while configuring the ACP Management Ethernet Port: %s.
ErrorString (STRING): Error string.
