acp.sock events
acp.sock.error
- Severity
ERROR
- Description
This message occurs when the system encounters a socket error while setting up the Alternate Control Path (ACP) Management Ethernet port. ACP functionality is subsequently inactive.
- Corrective Action
Verify that the Ethernet cable is properly attached to the ACP port and that the green LED is on. Reenable the ACP using the "options acp.enabled on" command.
- Syslog Message
An error was encountered while configuring the ACP Management Ethernet Port: %s.
- Parameters
ErrorString (STRING): Error string.
