ONTAP EMS reference
lmgr.lock events
lmgr.lock EMS events occur when ONTAP encounters issues associated with the volume lock reclaim process.
lmgr.lock.reclaim.aborted
Severity
ERROR
This message occurs when the system aborts the volume lock reclaim process. A volume attempts to reclaim file locks when you bring the volume online after a reboot or after a takeover or giveback event. This error is usually caused by the volumes going offline during the initialization process.
Corrective Action
None;When the volumes come back online the reclaim process will be restarted.
Syslog Message
Aborting Lock manager grace period initialization on volume %s due to error: %s.
aggr (STRING): The name of the aggregate.
error (STRING): Error code.
lmgr.lock.type.counts
Severity
NOTICE
This message provides additional information about the current count of lock manager objects when a lock manager pool limit is reached. The combination of the counts from a message indicating a limit has been reached and this message provide context for investigating and resolving the limit issues.
Corrective Action
(None).
Syslog Message
The number of lock manager object types in pool %s are: share locks %u byte locks %u waiting locks %u callback waiting %u pfs (clustered Data ONTAP FlexCache delegations) %u cached locks %u WAN FlexCache delegations %u
pool_name (STRING): Name of the limit pool.
share (INT): Number of allocated share locks in the pool.
byte (INT): Number of allocated byte locks in the pool.
waiting (INT): Number of allocated waiting locks in the pool.
cb_waiting (INT): Number of allocated cb_waiting locks in the pool.
pfs (INT): Number of allocated clustered Data ONTAP® FlexCache® delegations in the pool.
cached (INT): Number of allocated clustered Data ONTAP FlexCache cached locks in the pool.
delegations (INT): Number of allocated WAN FlexCache delegations in the pool.
