lmgr.lock events
lmgr.lock EMS events occur when ONTAP encounters issues associated with the volume lock reclaim process.
lmgr.lock.reclaim.aborted
- Severity
ERROR
- Description
This message occurs when the system aborts the volume lock reclaim process. A volume attempts to reclaim file locks when you bring the volume online after a reboot or after a takeover or giveback event. This error is usually caused by the volumes going offline during the initialization process.
- Corrective Action
None;When the volumes come back online the reclaim process will be restarted.
- Syslog Message
Aborting Lock manager grace period initialization on volume %s due to error: %s.
- Parameters
aggr (STRING): The name of the aggregate.
error (STRING): Error code.
lmgr.lock.type.counts
- Severity
NOTICE
- Description
This message provides additional information about the current count of lock manager objects when a lock manager pool limit is reached. The combination of the counts from a message indicating a limit has been reached and this message provide context for investigating and resolving the limit issues.
- Corrective Action
(None).
- Syslog Message
The number of lock manager object types in pool %s are: share locks %u byte locks %u waiting locks %u callback waiting %u pfs (clustered Data ONTAP FlexCache delegations) %u cached locks %u WAN FlexCache delegations %u
- Parameters
pool_name (STRING): Name of the limit pool.
share (INT): Number of allocated share locks in the pool.
byte (INT): Number of allocated byte locks in the pool.
waiting (INT): Number of allocated waiting locks in the pool.
cb_waiting (INT): Number of allocated cb_waiting locks in the pool.
pfs (INT): Number of allocated clustered Data ONTAP® FlexCache® delegations in the pool.
cached (INT): Number of allocated clustered Data ONTAP FlexCache cached locks in the pool.
delegations (INT): Number of allocated WAN FlexCache delegations in the pool.
