ONTAP EMS reference
lic.cappool events
lic.cappool EMS events occur when ONTAP encounters issues associated with capacity pool license reassignment operations.
lic.cappool.reassign.abort
Severity
NOTICE
This message occurs when the system aborts an operation of reassigning nodes to a different capacity pool license, because another reassignment operation to a different capacity pool license in the same request has failed.
Corrective Action
Look for the "lic.cappool.failed" event that occurred about the same time, which caused the reassignment operation to abort.
Syslog Message
"Capacity pool license reassignment is aborted for nodes ("%s") to serial number "%s" due to failure to reassign other nodes to serial number "%s"."
aborted_node_names (STRING): Aborted list of node names.
aborted_pool_serial (STRING): Aborted capacity pool license serial number.
failed_pool_serial (STRING): Another reassignment operation to this capacity pool serial number has failed.
lic.cappool.reassign.done
Severity
NOTICE
This message occurs when the system successfully completes an operation of reassigning nodes to a different capacity pool license.
Corrective Action
(None).
Syslog Message
"Capacity pool license reassignment successfully completed for nodes ("%s") to license serial number "%s"."
node_names (STRING): List of node names that are reassigned to the new capacity pool license.
new_pool_serial (STRING): Capacity pool license serial number to which the nodes are reassigned.
lic.cappool.reassign.done.info
Severity
NOTICE
This message occurs when the system successfully completes an operation of reassigning nodes to a different capacity pool license with with a non-critical error, which does not affect the outcome of the ultimate operation.
Corrective Action
(None).
Syslog Message
"Capacity pool license reassignment successfully completed for nodes ("%s") to license serial number "%s" with non-critical error "%s"."
non_critical_error (STRING): Information about the non-critical error encountered during the reassignment operation.
lic.cappool.reassign.failed
Severity
ERROR
This message occurs when operation of reassigning nodes to a different capacity pool license fails.
Corrective Action
Resolve the error, which should clearly indicate why the operation has failed. Follow the instructions shown on the ONTAP Select Deploy utility from which the operation was initiated.
Syslog Message
"Capacity pool license reassignemnt to license serial number "%s" failed for nodes ("%s") with error: %s"
failed_pool_serial (STRING): Capacity pool license serial number to which the nodes failed to be reassigned.
failed_node_names (STRING): List of node names that failed to be reassigned to the new capacity pool license.
error (STRING): Reason for failure.
lic.cappool.reassign.start
Severity
NOTICE
This message occurs when the system starts an operation of reassigning nodes to a different capacity pool license.
Corrective Action
(None).
Syslog Message
"Capacity pool license reassignment started for nodes ("%s") to license serial number "%s"."
