lic.cappool events
lic.cappool EMS events occur when ONTAP encounters issues associated with capacity pool license reassignment operations.
lic.cappool.reassign.abort
- Severity
NOTICE
- Description
This message occurs when the system aborts an operation of reassigning nodes to a different capacity pool license, because another reassignment operation to a different capacity pool license in the same request has failed.
- Corrective Action
Look for the "lic.cappool.failed" event that occurred about the same time, which caused the reassignment operation to abort.
- Syslog Message
"Capacity pool license reassignment is aborted for nodes ("%s") to serial number "%s" due to failure to reassign other nodes to serial number "%s"."
- Parameters
aborted_node_names (STRING): Aborted list of node names.
aborted_pool_serial (STRING): Aborted capacity pool license serial number.
failed_pool_serial (STRING): Another reassignment operation to this capacity pool serial number has failed.
lic.cappool.reassign.done
- Severity
NOTICE
- Description
This message occurs when the system successfully completes an operation of reassigning nodes to a different capacity pool license.
- Corrective Action
(None).
- Syslog Message
"Capacity pool license reassignment successfully completed for nodes ("%s") to license serial number "%s"."
- Parameters
node_names (STRING): List of node names that are reassigned to the new capacity pool license.
new_pool_serial (STRING): Capacity pool license serial number to which the nodes are reassigned.
lic.cappool.reassign.done.info
- Severity
NOTICE
- Description
This message occurs when the system successfully completes an operation of reassigning nodes to a different capacity pool license with with a non-critical error, which does not affect the outcome of the ultimate operation.
- Corrective Action
(None).
- Syslog Message
"Capacity pool license reassignment successfully completed for nodes ("%s") to license serial number "%s" with non-critical error "%s"."
- Parameters
non_critical_error (STRING): Information about the non-critical error encountered during the reassignment operation.
lic.cappool.reassign.failed
- Severity
ERROR
- Description
This message occurs when operation of reassigning nodes to a different capacity pool license fails.
- Corrective Action
Resolve the error, which should clearly indicate why the operation has failed. Follow the instructions shown on the ONTAP Select Deploy utility from which the operation was initiated.
- Syslog Message
"Capacity pool license reassignemnt to license serial number "%s" failed for nodes ("%s") with error: %s"
- Parameters
failed_pool_serial (STRING): Capacity pool license serial number to which the nodes failed to be reassigned.
failed_node_names (STRING): List of node names that failed to be reassigned to the new capacity pool license.
error (STRING): Reason for failure.
lic.cappool.reassign.start
- Severity
NOTICE
- Description
This message occurs when the system starts an operation of reassigning nodes to a different capacity pool license.
- Corrective Action
(None).
- Syslog Message
"Capacity pool license reassignment started for nodes ("%s") to license serial number "%s"."
- Parameters
