ONTAP EMS reference
cf.nopartner_takeover events
cf.nopartner_takeover EMS events occur when the partner node fails but requested not to be taken over to prevent multiple, simultaneous RAID reconstructs from starting.
cf.noPartner_takeover
Severity
ERROR
This message occurs when the partner node fails but requested not to be taken over to prevent multiple, simultaneous RAID reconstructs from starting.
Corrective Action
Check the partner node for multiple disk or disk shelf failures, and then correct that situation. If you want takeover to occur, use the "storage failover takeover" command. If you want takeover to occur when disk or shelf failures occur, change the setting of the "raid.panic.missing.disks" option to '0' from the nodeshell.
Syslog Message
Failover monitor: Partner node is down, but requested not to be taken over.
(None).
