The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
cf.nopartner_takeover events
Creating your file...
Your file is ready
cf.noPartner_takeover
- Severity
ERROR
- Description
This message occurs when the partner node fails but requested not to be taken over to prevent multiple, simultaneous RAID reconstructs from starting.
- Corrective Action
Check the partner node for multiple disk or disk shelf failures, and then correct that situation. If you want takeover to occur, use the "storage failover takeover" command. If you want takeover to occur when disk or shelf failures occur, change the setting of the "raid.panic.missing.disks" option to '0' from the nodeshell.
- Syslog Message
Failover monitor: Partner node is down, but requested not to be taken over.
- Parameters
(None).
