wafl.c2c events
wafl.c2c EMS events occur when ONTAP encounters issues associated with cloud-to-cloud restore operations from object storage.
wafl.c2c.restore.scan.abort
- Severity
NOTICE
- Description
This message occurs when an operation to restore file(s)/volume from a cloud storage was aborted.
- Corrective Action
(None).
- Syslog Message
%s %s%s%s, %s Restore from cloud storage aborted.
- Parameters
type (STRING): The type of object (volume/aggregate)
owner (STRING): The volume owner
vol (STRING): The volume name
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
restore_type (STRING): Indicates whether the operation is Full Volume, Single File or On-demand Restore.
wafl.c2c.restore.scan.done
- Severity
NOTICE
- Description
This message occurs when an operation to restore file(s)/volume from a cloud storage was completed successfully.
- Corrective Action
(None).
- Syslog Message
%s %s%s%s, %s Restore from cloud storage completed.
- Parameters
wafl.c2c.restore.scan.failed
- Severity
ERROR
- Description
This message occurs when there is an error during restoring of file(s) or Volume from a Cloud storage.
- Corrective Action
(None).
- Syslog Message
Restoring file with inode %d from cloud has failed with error %d for the volume %s with FSID 0x%x during %s Restore.
- Parameters
fileid (INT): File identifier.
error (INT): Error Code.
vol (STRING): Volume name.
fsid (INT): File system identifier of the volume.
wafl.c2c.rst.fsize.exceeded
- Severity
NOTICE
- Description
This message occurs when the size of a file being restored exceeds the maximum file size allowed by the system during the restoration of either files or a volume from cloud storage. The restore operation will fail for that particular file or volume.
- Corrective Action
(None).
- Syslog Message
%s %s%s%s%s, FSID 0x%x, Restoring file with file ID %d from cloud has failed because the file size exceeded the maximum file size allowed on the current system, which is %lu bytes. The size of the file being restored is %lu bytes.
- Parameters
type (STRING): Type of object (volume or aggregate).
owner (STRING): Volume owner.
volident (STRING): Unique identifier for the volume if the volume name itself is insufficient.
maxsize (LONGINT): Maximum file size allowed on this system.
filesize (LONGINT): Size of the file being restored.
