wafl.c2c events
wafl.c2c EMS events occur when ONTAP encounters issues associated with cloud-to-cloud restore operations from object storage.
wafl.c2c.increase.vol.max.size.failed
- Severity
ERROR
- Description
This message occurs when attempt to increase volume max size limit during c2c restore fails due to an error.
- Corrective Action
(None).
- Syslog Message
Attempt to increase max size limit for volume:%s failed with Error:%d.
- Parameters
vvolname (STRING): Name of the volume.
errorCode (INT): Error code
wafl.c2c.od.restore.scan.cloud.config.failed
- Severity
NOTICE
- Description
This message occurs when cloud config is unavailable and SMC on-demand restore from object store failed to start.
- Corrective Action
(None).
- Syslog Message
Phase:%s of the on-demand restore process for volume:%s with FSID:0x%x has failed. Attempt to restart SMC on-demand restore on this volume will continue in the background.
- Parameters
restore_phase (STRING): Specifies the phase for which the restore has been failed.
vol (STRING): Volume name.
fsid (INT): File system identifier of the volume.
wafl.c2c.od.restore.scan.initiated
- Severity
NOTICE
- Description
This message occurs when an on-demand restore from object store has been initiated.
- Corrective Action
(None).
- Syslog Message
Phase:%s of the on-demand restore process for volume:%s with FSID:0x%x has initiated.
- Parameters
restore_phase (STRING): Specifies the phase for which the restore has been initiated.
wafl.c2c.od.restore.scan.restart.failed
- Severity
ALERT
- Description
This message occurs when SMC lazy restore scan restart attempt for transient error failed.
- Corrective Action
(None).
- Syslog Message
Restart Phase:%s of the on-demand restore process for volume:%s with FSID:0x%x has failed and error number %d. For more information or assistance, contact NetApp technical support.
- Parameters
error (INT): Error number.
wafl.c2c.restore.scan.abort
- Severity
NOTICE
- Description
This message occurs when an operation to restore file(s)/volume from a cloud storage was aborted.
- Corrective Action
(None).
- Syslog Message
%s %s%s%s, %s Restore from cloud storage aborted.
- Parameters
type (STRING): The type of object (volume/aggregate)
owner (STRING): The volume owner
vol (STRING): The volume name
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
restore_type (STRING): Indicates whether the operation is Full Volume, Single File or On-demand Restore.
wafl.c2c.restore.scan.done
- Severity
NOTICE
- Description
This message occurs when an operation to restore file(s)/volume from a cloud storage was completed successfully.
- Corrective Action
(None).
- Syslog Message
%s %s%s%s, %s Restore from cloud storage completed.
- Parameters
wafl.c2c.restore.scan.failed
- Severity
ERROR
- Description
This message occurs when there is an error during restoring of file(s) or Volume from a Cloud storage.
- Corrective Action
(None).
- Syslog Message
Restoring file with inode %d from cloud has failed with error %d for the volume %s with FSID 0x%x during %s Restore.
- Parameters
fileid (INT): File identifier.
error (INT): Error Code.
wafl.c2c.rst.fsize.exceeded
- Severity
NOTICE
- Description
This message occurs when the size of a file being restored exceeds the maximum file size allowed by the system during the restoration of either files or a volume from cloud storage. The restore operation will fail for that particular file or volume.
- Corrective Action
(None).
- Syslog Message
%s %s%s%s%s, FSID 0x%x, Restoring file with file ID %d from cloud has failed because the file size exceeded the maximum file size allowed on the current system, which is %lu bytes. The size of the file being restored is %lu bytes.
- Parameters
type (STRING): Type of object (volume or aggregate).
owner (STRING): Volume owner.
volident (STRING): Unique identifier for the volume if the volume name itself is insufficient.
maxsize (LONGINT): Maximum file size allowed on this system.
filesize (LONGINT): Size of the file being restored.
