ONTAP EMS reference
wafl.c2c events
wafl.c2c.increase.vol.max.size.failed
Severity
ERROR
This message occurs when attempt to increase volume max size limit during c2c restore fails due to an error.
Corrective Action
(None).
Syslog Message
Attempt to increase max size limit for volume:%s failed with Error:%d.
vvolname (STRING): Name of the volume.
errorCode (INT): Error code
wafl.c2c.od.restore.scan.cloud.config.failed
Severity
NOTICE
This message occurs when cloud config is unavailable and SMC on-demand restore from object store failed to start.
Corrective Action
(None).
Syslog Message
Phase:%s of the on-demand restore process for volume:%s with FSID:0x%x has failed. Attempt to restart SMC on-demand restore on this volume will continue in the background.
restore_phase (STRING): Specifies the phase for which the restore has been failed.
vol (STRING): Volume name.
fsid (INT): File system identifier of the volume.
wafl.c2c.od.restore.scan.initiated
Severity
NOTICE
This message occurs when an on-demand restore from object store has been initiated.
Corrective Action
(None).
Syslog Message
Phase:%s of the on-demand restore process for volume:%s with FSID:0x%x has initiated.
restore_phase (STRING): Specifies the phase for which the restore has been initiated.
wafl.c2c.od.restore.scan.restart.failed
Severity
ALERT
This message occurs when SMC lazy restore scan restart attempt for transient error failed.
Corrective Action
(None).
Syslog Message
Restart Phase:%s of the on-demand restore process for volume:%s with FSID:0x%x has failed and error number %d. For more information or assistance, contact NetApp technical support.
error (INT): Error number.
wafl.c2c.restore.scan.abort
Severity
NOTICE
This message occurs when an operation to restore file(s)/volume from a cloud storage was aborted.
Corrective Action
(None).
Syslog Message
%s %s%s%s, %s Restore from cloud storage aborted.
type (STRING): The type of object (volume/aggregate)
owner (STRING): The volume owner
vol (STRING): The volume name
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
restore_type (STRING): Indicates whether the operation is Full Volume, Single File or On-demand Restore.
wafl.c2c.restore.scan.done
Severity
NOTICE
This message occurs when an operation to restore file(s)/volume from a cloud storage was completed successfully.
Corrective Action
(None).
Syslog Message
%s %s%s%s, %s Restore from cloud storage completed.
wafl.c2c.restore.scan.failed
Severity
ERROR
This message occurs when there is an error during restoring of file(s) or Volume from a Cloud storage.
Corrective Action
(None).
Syslog Message
Restoring file with inode %d from cloud has failed with error %d for the volume %s with FSID 0x%x during %s Restore.
fileid (INT): File identifier.
error (INT): Error Code.
wafl.c2c.rst.fsize.exceeded
Severity
NOTICE
This message occurs when the size of a file being restored exceeds the maximum file size allowed by the system during the restoration of either files or a volume from cloud storage. The restore operation will fail for that particular file or volume.
Corrective Action
(None).
Syslog Message
%s %s%s%s%s, FSID 0x%x, Restoring file with file ID %d from cloud has failed because the file size exceeded the maximum file size allowed on the current system, which is %lu bytes. The size of the file being restored is %lu bytes.
type (STRING): Type of object (volume or aggregate).
owner (STRING): Volume owner.
volident (STRING): Unique identifier for the volume if the volume name itself is insufficient.
maxsize (LONGINT): Maximum file size allowed on this system.
filesize (LONGINT): Size of the file being restored.
