vifmgr.staticroute events
vifmgr.staticroute EMS events occur when ONTAP encounters issues associated with static route operations on Vservers or storage virtual machines (SVMs).
vifmgr.staticRoute.add
- Severity
NOTICE
- Description
This message occurs when a static route is added to a Vserver.
- Corrective Action
(None).
- Syslog Message
Static route created on Vserver %s: dest %s, gw %s, metric %u.
- Parameters
vserverName (STRING): Name of the Vserver on which the static route was added.
destination (STRING): The IP subnet to which the route applies.
gateway (STRING): The IP address of the gateway.
metric (INT): The metric of the route, used to determine its priority relative to other routes for the Vserver.
vifmgr.staticRoute.del
- Severity
NOTICE
- Description
This message occurs when a static route is deleted from a Vserver.
- Corrective Action
(None).
- Syslog Message
Static route deleted from Vserver %s: dest %s, gw %s, metric %u.
- Parameters
vserverName (STRING): Name of the Vserver from which the static route was deleted.
