ONTAP EMS reference
vifmgr.staticroute events
vifmgr.staticroute EMS events occur when ONTAP encounters issues associated with static route operations on Vservers or storage virtual machines (SVMs).
vifmgr.staticRoute.add
Severity
NOTICE
This message occurs when a static route is added to a Vserver.
Corrective Action
(None).
Syslog Message
Static route created on Vserver %s: dest %s, gw %s, metric %u.
vserverName (STRING): Name of the Vserver on which the static route was added.
destination (STRING): The IP subnet to which the route applies.
gateway (STRING): The IP address of the gateway.
metric (INT): The metric of the route, used to determine its priority relative to other routes for the Vserver.
vifmgr.staticRoute.del
Severity
NOTICE
This message occurs when a static route is deleted from a Vserver.
Corrective Action
(None).
Syslog Message
Static route deleted from Vserver %s: dest %s, gw %s, metric %u.
vserverName (STRING): Name of the Vserver from which the static route was deleted.
