ONTAP EMS reference
vifmgr.staticroute events
vifmgr.staticRoute.add
Severity
NOTICE
This message occurs when a static route is added to a Vserver.
Corrective Action
(None).
Syslog Message
Static route created on Vserver %s: dest %s, gw %s, metric %u.
vserverName (STRING): Name of the Vserver on which the static route was added.
destination (STRING): The IP subnet to which the route applies.
gateway (STRING): The IP address of the gateway.
metric (INT): The metric of the route, used to determine its priority relative to other routes for the Vserver.
vifmgr.staticRoute.del
Severity
NOTICE
This message occurs when a static route is deleted from a Vserver.
Corrective Action
(None).
Syslog Message
Static route deleted from Vserver %s: dest %s, gw %s, metric %u.
vserverName (STRING): Name of the Vserver from which the static route was deleted.
vifmgr.staticRoute.netadd
Severity
NOTICE
This message occurs when a static route is added to the network routing table of a storage virtual machine (SVM).
Corrective Action
(None).
Syslog Message
Static route added to the network routing table for SVM %u: dest %s, gw %s, metric %u.
SVM (INT): ID of the SVM on which the static route was added.
destination (STRING): IP subnet to which the route applies.
gateway (STRING): IP address of the gateway.
metric (INT): Metric of the route, used to determine its priority relative to other routes for the SVM.
vifmgr.staticRoute.netremove
Severity
NOTICE
This message occurs when a static route is removed from the network routing table of a storage virtual machine (SVM).
Corrective Action
(None).
Syslog Message
Static route removed from the routing table for SVM %u: dest %s, gw %s.
SVM (INT): ID of the SVM from which the static route was deleted.
