vifmgr.staticroute events
vifmgr.staticroute EMS events occur when ONTAP encounters issues associated with static route operations on Vservers or storage virtual machines (SVMs).
vifmgr.staticRoute.add
- Severity
NOTICE
- Description
This message occurs when a static route is added to a Vserver.
- Corrective Action
(None).
- Syslog Message
Static route created on Vserver %s: dest %s, gw %s, metric %u.
- Parameters
vserverName (STRING): Name of the Vserver on which the static route was added.
destination (STRING): The IP subnet to which the route applies.
gateway (STRING): The IP address of the gateway.
metric (INT): The metric of the route, used to determine its priority relative to other routes for the Vserver.
vifmgr.staticRoute.del
- Severity
NOTICE
- Description
This message occurs when a static route is deleted from a Vserver.
- Corrective Action
(None).
- Syslog Message
Static route deleted from Vserver %s: dest %s, gw %s, metric %u.
- Parameters
vserverName (STRING): Name of the Vserver from which the static route was deleted.
vifmgr.staticRoute.netadd
- Severity
NOTICE
- Description
This message occurs when a static route is added to the network routing table of a storage virtual machine (SVM).
- Corrective Action
(None).
- Syslog Message
Static route added to the network routing table for SVM %u: dest %s, gw %s, metric %u.
- Parameters
SVM (INT): ID of the SVM on which the static route was added.
destination (STRING): IP subnet to which the route applies.
gateway (STRING): IP address of the gateway.
metric (INT): Metric of the route, used to determine its priority relative to other routes for the SVM.
vifmgr.staticRoute.netremove
- Severity
NOTICE
- Description
This message occurs when a static route is removed from the network routing table of a storage virtual machine (SVM).
- Corrective Action
(None).
- Syslog Message
Static route removed from the routing table for SVM %u: dest %s, gw %s.
- Parameters
SVM (INT): ID of the SVM from which the static route was deleted.
