      lun.outplace events
LUN.outplace.dumpRestoreFail
- Severity
ERROR
 - Description
This message occurs when an out-of-place restore of a LUN from dump fails because the source LUN is of a higher version than this Data ONTAP® release supports.
 - Corrective Action
Restore creates a regular file at the destination path, with the same data as in the source LUN. To recover the source LUN's data from the dump, you can create a new and unmapped LUN from this file using the 'lun create -f' command.
 - Syslog Message
An out-of-place restore of a LUN from dump for the destination path %s in volume %s (DSID %llu) failed.
 - Parameters
lun_path (STRING): Destination path for the failed LUN restore.
volume_name (STRING): Name of the destination volume.
volume_dsid (LONGINT): Data set ID (DSID) of the destination volume.
