The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
lun.outplace events
Creating your file...
Your file is ready
LUN.outplace.dumpRestoreFail
- Severity
ERROR
- Description
This message occurs when an out-of-place restore of a LUN from dump fails because the source LUN is of a higher version than this Data ONTAP® release supports.
- Corrective Action
Restore creates a regular file at the destination path, with the same data as in the source LUN. To recover the source LUN's data from the dump, you can create a new and unmapped LUN from this file using the 'lun create -f' command.
- Syslog Message
An out-of-place restore of a LUN from dump for the destination path %s in volume %s (DSID %llu) failed.
- Parameters
lun_path (STRING): Destination path for the failed LUN restore.
volume_name (STRING): Name of the destination volume.
volume_dsid (LONGINT): Data set ID (DSID) of the destination volume.
