      diskown.mcc events
diskown.mcc.AssignExceeded
- Severity
ERROR
 - Description
This message occurs when the number of drives assigned in the MetroCluster(tm) configuration exceeds the supported limit.
 - Corrective Action
Review the system capacity limits and the assigned drives on this system. If possible, unassign the unused array LUNs. If you need further assistance, contact NetApp technical support.
 - Syslog Message
The maximum number of drives that can be assigned in the configuration has exceeded. Total physical drive count: %d, maximum supported: %d.
 - Parameters
total_disk_count (INT): Total number of drives assigned in the configuration.
supported (INT): Number of drives supported.
