ONTAP EMS reference
diskown.mcc events
diskown.mcc EMS events occur when the number of drives assigned in the MetroCluster(tm) configuration exceeds the supported limit.
diskown.mcc.AssignExceeded
Severity
ERROR
This message occurs when the number of drives assigned in the MetroCluster(tm) configuration exceeds the supported limit.
Corrective Action
Review the system capacity limits and the assigned drives on this system. If possible, unassign the unused array LUNs. If you need further assistance, contact NetApp technical support.
Syslog Message
The maximum number of drives that can be assigned in the configuration has exceeded. Total physical drive count: %d, maximum supported: %d.
total_disk_count (INT): Total number of drives assigned in the configuration.
supported (INT): Number of drives supported.
