diskown.mcc events
Creating your file...
Your file is ready
diskown.mcc.AssignExceeded
- Severity
ERROR
- Description
This message occurs when the number of drives assigned in the MetroCluster(tm) configuration exceeds the supported limit.
- Corrective Action
Review the system capacity limits and the assigned drives on this system. If possible, unassign the unused array LUNs. If you need further assistance, contact NetApp technical support.
- Syslog Message
The maximum number of drives that can be assigned in the configuration has exceeded. Total physical drive count: %d, maximum supported: %d.
- Parameters
total_disk_count (INT): Total number of drives assigned in the configuration.
supported (INT): Number of drives supported.
