The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
san.noportsinipspace events
Creating your file...
Your file is ready
san.NoPortsInIpspace
- Severity
ERROR
- Description
This message occurs when an attempt to place an iSCSI LIF on a particular node fails because the system cannot find any ports in an IPspace on that node.
- Corrective Action
Add at least one port belonging to the node to the IPspace by using the "network port broadcast-domain add-ports" command and then resynchronize the Vserver configuration using the "metrocluster vserver resync" command.
- Syslog Message
Cannot find ports in IPspace "%s" on Node "%s" for placing LIF "%s" in Vserver "%s".
- Parameters
ipspace_name (STRING): IPspace name.
node_name (STRING): Node name.
lif (STRING): LIF name.
vserver_name (STRING): Vserver name.
