ONTAP EMS reference
san.noportsinipspace events
san.noportsinipspace EMS events occur when an attempt to place an IP LIF on a particular node fails because the system cannot find any ports in an IPspace on that node.
san.NoPortsInIpspace
Severity
ERROR
This message occurs when an attempt to place an IP LIF on a particular node fails because the system cannot find any ports in an IPspace on that node.
Corrective Action
Add at least one port belonging to the node to the IPspace by using the "network port broadcast-domain add-ports" command and then resynchronize the SVM configuration using the "metrocluster vserver resync" command.
Syslog Message
Cannot find ports in IPspace "%s" on node "%s" for placing LIF "%s" in SVM "%s".
ipspace_name (STRING): IPspace name.
node_name (STRING): Node name.
lif (STRING): LIF name.
vserver_name (STRING): SVM name.
