cr.del events
Creating your file...
CR.Del.CrptStreamData.Fail
- Deprecated
Deprecated as of Data ONTAP 9.6 because Infinite Volumes no longer exist.
- Severity
NOTICE
- Description
This message occurs when an attempt to delete corrupt stream data fails.
- Corrective Action
(None).
- Syslog Message
Deletion failed for corrupt stream data [%s] on volume [%s] in Vserver [%s].
- Parameters
path (STRING): Stream path.
volume (STRING): Name of the constituent volume where the stream resides.
vserver (STRING): Vserver hosting the volume.
CR.Del.CrptStreamRedir.Fail
- Deprecated
- Severity
NOTICE
- Description
This message occurs when an attempt to delete corrupt stream redirector failed.
- Corrective Action
(None).
- Syslog Message
Deletion failed for corrupt stream redirector [%s] on volume [%s] in Vserver [%s].
- Parameters
CR.Del.DangStreamData.Fail
- Deprecated
- Severity
NOTICE
- Description
This message occurs when an attempt to delete dangling stream data fails. This stream was created when there was a failure in cleaning up stream data on the data constituent, which left dangling data that is unnecessarily consuming resources.
- Corrective Action
(None).
- Syslog Message
Deletion failed for dangling stream data [%s] on volume [%s] in Vserver [%s].
- Parameters
volume (STRING): Name of the constituent volume where the stream data resides.
CR.Del.DangStreamRedir.Fail
- Deprecated
- Severity
NOTICE
- Description
This message occurs when an attempt to delete dangling stream redirector failed.
- Corrective Action
(None).
- Syslog Message
Deletion failed for dangling stream redirector [%s] on volume [%s] in Vserver [%s].
- Parameters
volume (STRING): Name of the constituent volume where the redirector resides.
