ONTAP EMS reference
cr.del events
CR.Del.CrptStreamData.Fail
Deprecated
Deprecated as of Data ONTAP 9.6 because Infinite Volumes no longer exist.
Severity
NOTICE
This message occurs when an attempt to delete corrupt stream data fails.
Corrective Action
(None).
Syslog Message
Deletion failed for corrupt stream data [%s] on volume [%s] in Vserver [%s].
path (STRING): Stream path.
volume (STRING): Name of the constituent volume where the stream resides.
vserver (STRING): Vserver hosting the volume.
CR.Del.CrptStreamRedir.Fail
Deprecated
Severity
NOTICE
This message occurs when an attempt to delete corrupt stream redirector failed.
Corrective Action
(None).
Syslog Message
Deletion failed for corrupt stream redirector [%s] on volume [%s] in Vserver [%s].
CR.Del.DangStreamData.Fail
Deprecated
Severity
NOTICE
This message occurs when an attempt to delete dangling stream data fails. This stream was created when there was a failure in cleaning up stream data on the data constituent, which left dangling data that is unnecessarily consuming resources.
Corrective Action
(None).
Syslog Message
Deletion failed for dangling stream data [%s] on volume [%s] in Vserver [%s].
volume (STRING): Name of the constituent volume where the stream data resides.
CR.Del.DangStreamRedir.Fail
Deprecated
Severity
NOTICE
This message occurs when an attempt to delete dangling stream redirector failed.
Corrective Action
(None).
Syslog Message
Deletion failed for dangling stream redirector [%s] on volume [%s] in Vserver [%s].
volume (STRING): Name of the constituent volume where the redirector resides.
