The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
netif.toomanynics events
Creating your file...
Your file is ready
netif.tooManyNics
- Severity
ERROR
- Description
This message occurs when a network interface was not initialized because the number of interfaces of this type exceeds the maximum supported.
- Corrective Action
Remove a network interface card (NIC).
- Syslog Message
Network interface %s was not initialized because the number of interfaces of this type exceeds the maximum (%d) supported.
- Parameters
ifName (STRING): Name of the network interface; for example, "e8a".
maxIf (INT): Maximum number of interfaces of this type that is supported.
