The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
cifs.replay events
Creating your file...
Your file is ready
cifs.replay.failure
- Severity
ALERT
- Description
This message occurs when configuration is not synchronized. This might cause the node experiencing the problem to become unresponsive to data access.
- Corrective Action
Contact NetApp technical support. Be prepared to provide log files to technical support, particularly the "mgwd.log" and "sktrace.log" files.
- Syslog Message
Failed to replay configuration for %s module.
- Parameters
module (STRING): Name of the module for which configuration is not synchronized.
