cifs.replay events
cifs.replay.failure
- Severity
ALERT
- Description
This message occurs when configuration is not synchronized. This might cause the node experiencing the problem to become unresponsive to data access.
- Corrective Action
Contact NetApp technical support. Be prepared to provide log files to technical support, particularly the "mgwd.log" and "sktrace.log" files.
- Syslog Message
Failed to replay configuration for %s module.
- Parameters
module (STRING): Name of the module for which configuration is not synchronized.
