ONTAP EMS reference
cifs.replay events
cifs.replay.failure
Severity
ALERT
This message occurs when configuration is not synchronized. This might cause the node experiencing the problem to become unresponsive to data access.
Corrective Action
Contact NetApp technical support. Be prepared to provide log files to technical support, particularly the "mgwd.log" and "sktrace.log" files.
Syslog Message
Failed to replay configuration for %s module.
module (STRING): Name of the module for which configuration is not synchronized.
