      cifs.replay events
cifs.replay.failure
- Severity
ALERT
 - Description
This message occurs when configuration is not synchronized. This might cause the node experiencing the problem to become unresponsive to data access.
 - Corrective Action
Contact NetApp technical support. Be prepared to provide log files to technical support, particularly the "mgwd.log" and "sktrace.log" files.
 - Syslog Message
Failed to replay configuration for %s module.
 - Parameters
module (STRING): Name of the module for which configuration is not synchronized.
