fci.fwupdate events
fci.fwupdate EMS events occur when ONTAP encounters issues associated with Fibre Channel host bus adapter (HBA) firmware updates.
fci.fwupdate.AutoBoot
- Severity
NOTICE
- Description
This message occurs when the Service Level Initiator Fibre Channel (SLIFC) Initiator driver successfully updates the firmware of the host bus adapter (HBA).
- Corrective Action
None; the controller is rebooted automatically to enable the new HBA firmware.
- Syslog Message
FC Initiator HBA %s firmware updated from version %s to %s. The adapter will be reset automatically to enable the new HBA firmware.
- Parameters
hba (STRING): HBA where the firmware version update occurred.
currentversion (STRING): Firmware version the HBA is running.
bundleversion (STRING): Firmware version bundled with ONTAP® software.
fci.fwupdate.NeedBoot
- Severity
ERROR
- Description
This message occurs when the Service Level Interface Fibre Channel(SLIFC) Initiator driver successfully updates the firmware version of the host bus adapter (HBA), and requires a reboot of the controller to complete the process.
- Corrective Action
Reboot the controller to enable the new HBA firmware.
- Syslog Message
FC Initiator HBA %s firmware updated from version %s to %s. Reboot the controller to enable the new HBA firmware.
- Parameters
hba (STRING): HBA where the firmware update occurred.
currentversion (STRING): Firmware version the HBA was running.
fci.fwupdate.UpdDone
- Severity
NOTICE
- Description
- Corrective Action
(None).
- Syslog Message
FC Inititator HBA %s firmware updated successfully from version %s to %s.
- Parameters
fci.fwupdate.UpdErr
- Severity
ERROR
- Description
This message occurs when the Service Level Initiator Fibre Channel (SLIFC) Initiator driver encounters an error while updating the firmware of the host bus adapter (HBA).
- Corrective Action
Contact NetApp technical support for further analysis.
- Syslog Message
FC Initator HBA %s failed to update the firmware from version %s to %s with the status of %d.
- Parameters
hba (STRING): HBA where the firmware update failure occurred.
status (INT): Status code of the firmware update process.
