ONTAP EMS reference
fci.fwupdate events
fci.fwupdate EMS events occur when ONTAP encounters issues associated with Fibre Channel host bus adapter (HBA) firmware updates.
fci.fwupdate.AutoBoot
Severity
NOTICE
This message occurs when the Service Level Initiator Fibre Channel (SLIFC) Initiator driver successfully updates the firmware of the host bus adapter (HBA).
Corrective Action
None; the controller is rebooted automatically to enable the new HBA firmware.
Syslog Message
FC Initiator HBA %s firmware updated from version %s to %s. The adapter will be reset automatically to enable the new HBA firmware.
hba (STRING): HBA where the firmware version update occurred.
currentversion (STRING): Firmware version the HBA is running.
bundleversion (STRING): Firmware version bundled with ONTAP® software.
fci.fwupdate.NeedBoot
Severity
ERROR
This message occurs when the Service Level Interface Fibre Channel(SLIFC) Initiator driver successfully updates the firmware version of the host bus adapter (HBA), and requires a reboot of the controller to complete the process.
Corrective Action
Reboot the controller to enable the new HBA firmware.
Syslog Message
FC Initiator HBA %s firmware updated from version %s to %s. Reboot the controller to enable the new HBA firmware.
hba (STRING): HBA where the firmware update occurred.
currentversion (STRING): Firmware version the HBA was running.
fci.fwupdate.UpdDone
Severity
NOTICE
Corrective Action
(None).
Syslog Message
FC Inititator HBA %s firmware updated successfully from version %s to %s.
fci.fwupdate.UpdErr
Severity
ERROR
This message occurs when the Service Level Initiator Fibre Channel (SLIFC) Initiator driver encounters an error while updating the firmware of the host bus adapter (HBA).
Corrective Action
Contact NetApp technical support for further analysis.
Syslog Message
FC Initator HBA %s failed to update the firmware from version %s to %s with the status of %d.
hba (STRING): HBA where the firmware update failure occurred.
status (INT): Status code of the firmware update process.
