fci.fwupdate events
fci.fwupdate.AutoBoot
- Severity
NOTICE
 - Description
This message occurs when the Service Level Initiator Fibre Channel (SLIFC) Initiator driver successfully updates the firmware of the host bus adapter (HBA).
 - Corrective Action
None; the controller is rebooted automatically to enable the new HBA firmware.
 - Syslog Message
FC Initiator HBA %s firmware updated from version %s to %s. The adapter will be reset automatically to enable the new HBA firmware.
 - Parameters
hba (STRING): HBA where the firmware version update occurred.
currentversion (STRING): Firmware version the HBA is running.
bundleversion (STRING): Firmware version bundled with ONTAP® software.
fci.fwupdate.NeedBoot
- Severity
NOTICE
 - Description
This message occurs when the Service Level Interface Fibre Channel (SLIFC) Initiator driver successfully updates the firmware version of the host bus adapter (HBA), and requires a reboot of the controller to complete the process.
 - Corrective Action
(None).
 - Syslog Message
FC Initiator HBA %s firmware updated from version %s to %s. Reboot the controller to enable the new HBA firmware.
 - Parameters
hba (STRING): HBA where the firmware update occurred.
fci.fwupdate.UpdDone
- Severity
NOTICE
 - Description
 - Corrective Action
(None).
 - Syslog Message
FC Inititator HBA %s firmware updated successfully from version %s to %s.
 - Parameters
currentversion (STRING): Firmware version the HBA was running.
fci.fwupdate.UpdErr
- Severity
ERROR
 - Description
This message occurs when the Service Level Initiator Fibre Channel (SLIFC) Initiator driver encounters an error while updating the firmware of the host bus adapter (HBA).
 - Corrective Action
Contact NetApp technical support for further analysis.
 - Syslog Message
FC Initator HBA %s failed to update the firmware from version %s to %s with the status of %d.
 - Parameters
hba (STRING): HBA where the firmware update failure occurred.
status (INT): Status code of the firmware update process.
