vifmgr.lifmove events
Creating your file...
Your file is ready
vifmgr.lifmove.blocked
- Severity
NOTICE
- Description
This message occurs when an attempt to move a logical interface (LIF) IP address to another node/port due to a load-balance event has failed because the LIF has active connections which can not be safely migrated.
- Corrective Action
(None).
- Syslog Message
LIF %s (on virtual server %s), IP address %s, was blocked when being moved to node %s, port %s.
- Parameters
vifname (STRING): Name of the LIF that is being moved.
vsrvid (STRING): Name of the virtual server identifier on which this LIF resides.
vifip (STRING): The logical interface's IP address that is being moved.
tonode (STRING): Name of the node to where the LIF is moving.
toport (STRING): Name of the port to where the LIF is moving.
