The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vifmgr.lifmove events
Creating your file...
Your file is ready
vifmgr.lifmove.blocked
- Severity
NOTICE
- Description
This message occurs when an attempt to move a logical interface (LIF) IP address to another node/port due to a load-balance event has failed because the LIF has active connections which can not be safely migrated.
- Corrective Action
(None).
- Syslog Message
LIF %s (on virtual server %s), IP address %s, was blocked when being moved to node %s, port %s.
- Parameters
vifname (STRING): Name of the LIF that is being moved.
vsrvid (STRING): Name of the virtual server identifier on which this LIF resides.
vifip (STRING): The logical interface's IP address that is being moved.
tonode (STRING): Name of the node to where the LIF is moving.
toport (STRING): Name of the port to where the LIF is moving.
