extcache.configunsupported events
Creating your file...
Your file is ready
extCache.configUnsupported
- Severity
ERROR
- Description
This message occurs when the controller contains an external cache hardware configuration that cannot be supported on the controller.
- Corrective Action
Consult the release documentation, check the Interoperability Matrix Tool (IMT) for a supported configuration, or contact Contact NetApp technical support. to understand and correct the hardware configuration.
- Syslog Message
WAFL external cache hardware configuration is not supported: %s.
- Parameters
description (STRING): String providing information about why the configuration is unsupported.
