ONTAP EMS reference
extcache.configunsupported events
extcache.configunsupported EMS events occur when the controller contains an external cache hardware configuration that cannot be supported on the controller.
extCache.configUnsupported
Severity
ERROR
This message occurs when the controller contains an external cache hardware configuration that cannot be supported on the controller.
Corrective Action
Consult the release documentation, check the Interoperability Matrix Tool (IMT) for a supported configuration, or contact Contact NetApp technical support. to understand and correct the hardware configuration.
Syslog Message
WAFL external cache hardware configuration is not supported: %s.
description (STRING): String providing information about why the configuration is unsupported.
