ONTAP EMS reference
nblade.fpolpsvolofflined events
nblade.fpolpsvolofflined EMS events occur when persistent store volume is offline.
Nblade.fpolPsVolOfflined
Severity
ERROR
This message occurs when persistent store volume is offline. This causes disruption in FPolicy where persistent store is enabled.
Corrective Action
Check the volume corresponding to the persistent store. Either online the volume for use or delete the corresponding persistent store.
Syslog Message
FPolicy persistent store volume "%s" belonging to SVM "%s" is offline.
volName (STRING): Persistent store volume.
vserverName (STRING): Name of the SVM.
