ONTAP EMS reference
lmgr.session events
lmgr.session EMS events occur when a SpinNP session has failed, which causes session-scoped (e.g.
lmgr.session.failed
Severity
INFORMATIONAL
This event occurs when a SpinNP session has failed, which causes session-scoped (e.g. CIFS) locks on the D-blade to be dropped. Only affects locks acquired using the failed session. This will cause clients to see a service disruption until they re-connect to the server.
Corrective Action
None — clients will automatically try to reconnect to the server, re-locking files as necessary.
Syslog Message
Dropped session-scoped locks from session %s:%s:%s due to failed session.
initiator (STRING): The blade ID of the initiator.
uniquifier (STRING): The session uniquifier.
target (STRING): The blade ID of the target.
