The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
lmgr.session events
Creating your file...
Your file is ready
lmgr.session.failed
- Severity
INFORMATIONAL
- Description
This event occurs when a SpinNP session has failed, which causes session-scoped (e.g. CIFS) locks on the D-blade to be dropped. Only affects locks acquired using the failed session. This will cause clients to see a service disruption until they re-connect to the server.
- Corrective Action
None — clients will automatically try to reconnect to the server, re-locking files as necessary.
- Syslog Message
Dropped session-scoped locks from session %s:%s:%s due to failed session.
- Parameters
initiator (STRING): The blade ID of the initiator.
uniquifier (STRING): The session uniquifier.
target (STRING): The blade ID of the target.
