The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
wafl.extent events
Creating your file...
Your file is ready
wafl.extent.size.reset
- Severity
NOTICE
- Description
This message occurs when the volume extent option is set and WAFL® encounters an invalid extent size. This message indicates that the extent size was reset to a valid default value.
- Corrective Action
(None).
- Syslog Message
Extent size for volume %s was reset to %d.
- Parameters
vol (STRING): Name of the volume.
extent_size (INT): New extent size.
