      cmd.shelfchk events
cmd.shelfchk.config.OK
- Severity
INFORMATIONAL
 - Description
This event is generated while verifying disk shelf cabling and configuration. The operator indicates that the correct disk LEDs have illuminated.
 - Corrective Action
(None).
 - Syslog Message
Disk Configuration - No Errors Identified.
 - Parameters
(None).
cmd.shelfchk.config.warning
- Severity
ERROR
 - Description
This event is generated while verifying disk shelf cabling and configuration on a channel. The operator has indicated that the intended set of disk LEDs is not illuminated.
 - Corrective Action
Verify that the adapters and storage shelves are cabled correctly.
 - Syslog Message
Disk Configuration - Failure Identified by Operator.
 - Parameters
(None).
