cmd.shelfchk events
Creating your file...
Your file is ready
cmd.shelfchk.config.OK
- Severity
INFORMATIONAL
- Description
This event is generated while verifying disk shelf cabling and configuration. The operator indicates that the correct disk LEDs have illuminated.
- Corrective Action
(None).
- Syslog Message
Disk Configuration - No Errors Identified.
- Parameters
(None).
cmd.shelfchk.config.warning
- Severity
ERROR
- Description
This event is generated while verifying disk shelf cabling and configuration on a channel. The operator has indicated that the intended set of disk LEDs is not illuminated.
- Corrective Action
Verify that the adapters and storage shelves are cabled correctly.
- Syslog Message
Disk Configuration - Failure Identified by Operator.
- Parameters
(None).
