The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
cmd.shelfchk events
Creating your file...
Your file is ready
cmd.shelfchk.config.OK
- Severity
INFORMATIONAL
- Description
This event is generated while verifying disk shelf cabling and configuration. The operator indicates that the correct disk LEDs have illuminated.
- Corrective Action
(None).
- Syslog Message
Disk Configuration - No Errors Identified.
- Parameters
(None).
cmd.shelfchk.config.warning
- Severity
ERROR
- Description
This event is generated while verifying disk shelf cabling and configuration on a channel. The operator has indicated that the intended set of disk LEDs is not illuminated.
- Corrective Action
Verify that the adapters and storage shelves are cabled correctly.
- Syslog Message
Disk Configuration - Failure Identified by Operator.
- Parameters
(None).
