ONTAP EMS reference
smbc.aufo events
smbc.aufo EMS events occur when ONTAP encounters issues associated with SnapMirror® active sync automatic unplanned failover operations.
smbc.aufo.completed
Severity
NOTICE
This message occurs when the SnapMirror® Business Continuity (SMBC) automatic unplanned failover operation completes.
Corrective Action
(None).
Syslog Message
SnapMirror automatic failover completed. Destination path: %s.
dstpath (STRING): Path name of the destination group of the SMBC relationship.
smbc.aufo.during.expand
Severity
NOTICE
This message occurs when a SnapMirror® Business Continuity (SM-BC) automatic unplanned failover operation starts while a SnapMirror Business Continuity expand operation is in progress. The new volumes of the consistency group that are going through the expand operation do not participate in the failover and remain as data protection (DP) after completion of failover.
Corrective Action
(None).
Syslog Message
Automatic unplanned failover has started on the SnapMirror Business Continuity relationship while the relationship is expanding. The new volumes of the consistency group that are going through the expand operation do not participate in the failover and remain as DP after completion of failover.
dstpath (STRING): Path name for the destination consistency group of SM-BC relationship.
smbc.aufo.failed
Severity
ERROR
This message occurs when the SnapMirror® Business Continuity (SMBC) automatic unplanned failover operation fails.
Corrective Action
Perform "snapmirror delete -destination-path destination_path" followed by "snapmirror break" on the volumes.
Syslog Message
SnapMirror automatic failover failed. Destination path: %s.
smbc.aufo.failover.incapable
Severity
ERROR
This message occurs when the SnapMirror® Business Continuity (SMBC) automatic unplanned failover operation fails because the destination site is not failover capable.
Corrective Action
Before applying corrective action, the User must ensure that the primary/master copy is unavailable, otherwise the assumption is that Master copy is actively being used by the Application workload. Perform "snapmirror delete -destination-path destination_path" followed by "snapmirror break" on the volumes.
Syslog Message
SnapMirror automatic failover encountered a failure because the site with destination path "%s" is not failover-capable.
smbc.aufo.io.outage.complete
Severity
NOTICE
This message occurs when I/O can resume after an automatic unplanned failover of a SnapMirror Business Continuity (SMBC) relationship.
Corrective Action
(None).
Syslog Message
In the automatic unplanned failover of the SMBC relationship with destination path %s and relationship-ID %s, I/O disruption started at %s and lasted for %u msecs. Mediator Agent processing started at %s and lasted for %u msecs.
dstpath (STRING): Destination path of the SMBC relationship.
cg_rel_id (STRING): ID of the SMBC relationship.
io_outage_start_time (STRING): I/O disruption start time.
io_outage_latency (LONGINT): I/O disruption window (msecs).
tba_trigger_start_time (STRING): Mediator Agent processing start time.
tba_trigger_latency (LONGINT): Mediator Agent processing window (msecs).
smbc.aufo.queued
Severity
NOTICE
This message occurs when the SnapMirror® Business Continuity (SMBC) automatic unplanned failover operation is queued.
Corrective Action
(None).
Syslog Message
SnapMirror Business Continuity (SMBC) automatic unplanned operation failover queued. Destination path: %s.
smbc.aufo.start
Severity
NOTICE
This message occurs when the SnapMirror® Business Continuity (SMBC) automatic unplanned failover operation starts.
Corrective Action
(None).
Syslog Message
SnapMirror automatic failover started. Destination path: %s.
